PaulJL
0
Noo idea what you just said. Good job that I'm not painting mine..I set it at 2 bar at the gun. I also set it at full paint flow before pressurising up by screwing the adjuster out, pull the trigger and wind the adjuster back in so you can feel it touch the trigger stop. I use a 50/50 mix paint to thinners and about a hand span spread with about a 25% overlap on the passes.
