Betty the Commer Pizza Truck Project.
These engines weren't fitted with proper stem seals just 'O' rings that were supposed to stop oil from going down the bores when the engine is idle optimistically called 'sealing rings' in the manual. Not very effective and but better than nothing and should be included in the head set. Just looked at the head set on aBay and they can be seen in pairs in the bore holes in the gasket.
yeah i did see those and think they just looked mega small and different to what i had seen online, thanks buddy, taking the head to the brother in law tomorrow and hes going to teach me how to sort it all out and do any machine work needed so shes looking like shes saved
Good to have someone who can help
Thought I’d update you, heads fine! Somehow it’s gone in, through the valve, out the other end without even hitting it! Then landed flat In the piston area. I’m a Lucky man!
Also. The eBay gasket set you linked, they are based literally a 20 min drive from me, drove down today to collect it to save faff with postage and waiting, tomorrow I’ll put new rings on the valves and then Wednesday onwards I’ll be putting her back together !
Hopefully by Saturday she’ll be running again!
Need to hunt a new dizzy and potential coil but might do that later down the line as I now know how to get to all that fairly easily.
Been a wild few days
Gasket Peoples contact details below if you ever need them. They stock tons and were a lovely bunch, most is NOS stock too
Slowly putting her back together! The side cover thing where the tappets are barely had a gasket on it before so I suppose it’s good to have all new gaskets everywhere !
Starting to come back together now! A clean table so the Roast dinner is on for Sunday!
Gave her a push in 4th gear and the valves and rocker gear all moving correctly with no lock ups which is promising.
The gasket set, the thermostat cover bit didn’t fit so need to make one for that. The rest of the gasket kit was spot on for anyone wondering.
Next week I can get back to building the gas box for the rear then need to get the dizzy valve clearances and timing sorted then she should be good to go!
