workshop heating system
PaulJL
Thinking of a tube into it like a pan handle shape. Lighting it was easy, I dropped a couple of lighter blocks and a aerosol lid of paraffin, when the paraffin started fizzing I put two lids full of oil in. Burned for 20mins.when its in the stove it will have a drip feed oil supply so once it's lit it should keep going until the oil is switched off
PaulJL
Got my plumbing ordered including a length of stainless steel pipe for the drip feed. Found a suitable tank too
PaulJL
Plumbing stuff turned up within 24 hours! Toolstation are ace! Free postage too.
Had a play today, fitted some swirl plates which do exactly as they say on the tin.
Found a suitable oil tank too.....
PaulJL
Hopefully getting the flu up tomorrow if the weather is dry... Don't fancy cutting holes in the roof in the rain.
PaulJL
The first picpis the flue temperature, the second is the blown air temperature.... The third is what the others are....
PaulJL
Had a a play tonight, managed to get the blown air temperature up to 250°C!
PaulJL
By the time I upgrade the fan and fit the ducting the outlet temperature at the end of the ducting will be lower...
S0updragon
Now you need to make a small one that would blow warm air into a camper. Then sit round it in the evening to keep warm and have a nice toasty camper when it’s bed time:):)
PaulJL
Got it to 300 degrees C and got the stove glowing!
