Summer will soon be here!
You could use PTFE,Nylon,Oilon,Delrin,Peek, or something similar ;)
Nice job on the heater[^] I found although it's noisy it does pump the heat out:)
Is the other nice little bit of fabbing part of the cable duct that goes across the middle of the cab floor?
How refreshing
yes it is, to be fare the one it's replacing wasn't all that bad as you can see. I could make a better one so I did :D
powered by rust and brimstone !
It's nice to know that it's there even though you rarely see it:) I made a new ducting up but didn't fit it:I It makes a nasty bump in the carpet;)
How refreshing
heater box looks great m8, im tackling that soon but mine is well rotten lol
On iceman when rewiring I re routed the loom to drop down at the front and go under the cab floor. As Panky says no more bump in the carpet... Er if I had carpet :/
I just need a good rootes...
Yeah mine wasn't good, I was contemplating making a new one rather than fix it.
I also don't like the idea of the lump in the carpet, I am thinking of moving the few wires under the floor rather than over it.
mine is about the same as that :) im thinking about replacing the rotten section with a bolt in plastic piece to stop it rotting again but im not sure yet. interesting idea about moving the floor wires. i may go that route myself
And yet more work, I'm now sat here in front of the laptop smelling 2 pack with every breath lol. This means I have had a good day :)
My nice red floor got a little covered in over spray :-(
Hope you using an air fed mask or you will soon be dead and you wont get chance to even drive your commer[:0][:0]
A commer with even bigger boost will be appering on a screen near you soon!
More amazing work-well done on the heater! -they do work well when renovated! Mr M saved mine.
Mike/ Clarabel and Co /Hazels Dad
nicely done m8, i have never touched a rear axle so im in for fun when i do mine haha
