Summer will soon be here!
Looking good Dan [8D]
Ace work there Dan. I know just exactly how much hard work has gone into the van! Cant beat the feeling of seeing it all come together. Looking forward to seeing this one back on the black top.
Looking very fresh under there dan, 100 times better than mine:eek: Good to meet you last week and many thanks for your time. (not sure if you got my message?) :)
thanks for the kind words People :D
Scott, I got your message yes and your more than welcome. Please do feel free to pop round again any time, and anything I can do to help just shout :)
powered by rust and brimstone !
More pic's
Any one have any suggestions on this?
This is my master cylinder as I took out it's innards (now it was working) but I think the last person here didn't remember how they took it apart and then just jammed it all back in. What bit should go where? the bit that I'm not to sure about is the white plastic bit and the metal washer "thing" that is stuck over it?
Pretty sure they are in the right order, the forks on the white plastic bit fit into the end of the spring and the washer sits between the plastic bit and the end of the spring. The tabs on the washer look like they will fit inside the spring to hold it in position.
How refreshing
How refreshing
But as you see it is how it came out. the washer was half over, and one of the legs on the white thing was snapped over!
It's buggered, as you say its been jammed in and mis-aligned. A seal kit has all those bits in it and is cheap:)
How refreshing
one already on its way from speedy spares, £3.50 I think. No point even trying to put it back together right at that price :) and thanks for the kind words about the work guys. I love the ego boost I get from this site, makes all the hard work worth while :D
This place certainly kept me going through the less than easy times:)
How refreshing
How refreshing
Emotion's are very seconded;):D
hi mate ,what type of hydrolic ramp are you using to lift the van off the ground, and where did you get it from?;):p
Big Bad Woolf
