never in your wildest dreams!Well. Work have closed for 3 weeks. I'm getting fully paid, I'm at home alone as I cant visit the other half so...I'm in the garage.
Yes. Needed one as the back brakes are now bigger than the frontsIs that a bias valve?
Cracking idea!So you've got a porthole and vents from a tank, you need something from a plane now and that's all the armed services covered![]()
No idea what that is..System from a Max 8 to keep the nose on the ground. They're cheap ATM.
Just put a cheeky bid on an air speed indicator. Goes up to Mach 1. Should be ok....So you've got a porthole and vents from a tank, you need something from a plane now and that's all the armed services covered![]()
