So........
Peiced in some shiny new steel tube into the flow and return from the tank with compression fittings to replace the rusty sections over the back axle.
Being diesel, there is no lining to the fuel tank, so it doesn't suffer from the dreaded "snakeskin", and the tanks don't have much water in the bottom due to the flow and return system depositing the water in the sediment bowl.
Here's bacterial gloop growing on the boundary between the water and diesel in the sediment bowl.
All cleaned out and reconnected.
Next, a look at the front end.
Obviously a new front valance is required, along with a drivers step and inner cill.
Then on to the front brakes and suspension.
Off with the drums.
I worked out a reliable method of removing and replacing those pesky brake springs.
Grip the end of the spring with mole grips, then lever it around the hub with a metal bar. seems to work every time without risking skinned knuckles etc.
The shoes are breaking up.
And the nearside wheel studs are worn.
Both will need to be replaced.
Time to drop the crossmember, as I could do with the extra room to weld the driver's inner cill, and it's caked in grease (not a bad thing by any means!).
All the time I've been slaving away in the barn, I have hardly noticed that spring is well on it's way outside.
The snowdrops might look a bit different tomorrow after I've pressure washed all the grease off the crossmember!
Commer PB Jennings
