Nice to have the forum back.
Panky: When we had an all Petrol fleet, I was clueless about the dark workings of oil burners, now
we're all diesel, (and a good deal of learning later) I wouldn't go back. It would be different if I did
more city driving though.
Anyway...........A few odd jobs to do down under.
The spare wheel carrier.
I strengthened the hinge fixings and the overcentre catch, as I've read that they have a tendancy to come
apart. It had also been hitched up to the chassis in a way that prevented it working at all. Strange. I also
added a big safety chain.
Engine reaction rod.
I added a strut from the gearbox mount to the engine/gearbox adaptor plate, to prevent the engine
shunting forward under braking. Not my idea, this one. My Karrier Bantam has one of these. The
washers and rubbers are "upcycled" from the old front shock absorbers.
Now on to the front valance. Gave it a poke, and found the thickest bit of filler so far.
The inner valance is ropey for a few inches at the bottom. I did the work in sections so that I would
have plenty of old metal left to measure against. As my patterns are made from A4 size sheets, my
replacement sections are about a foot long.
Here's the three near side sections just lightly tacked in place, because I want to trial fit the outer
valance before I fix them any more.
A trial fit of the new outer valance.
Note the differences between old and new. It's a rather unconventional join line between the two, but
there's method in my madness. Most of the weld will be just under the bottom flute, and behind the
grille. That will leave a couple of inches of visible weld line between the bottom of the grille and the
bumper line. That way I get to keep the original factory flutes, and the weld line won't be "in yer face"
right across the front. I'm happy to take the risk of a poor fit under the grille. Anyone want a set of
flutes without the rest of the valance?
Then the offside was done in similar fashion, this time trial fitting the air duct as well to make sure it
would all fit OK.Anyway, trial fit done and inner valance adjusted to fit, so it was all welded up.
Then a coat of primer.
I'll leave the outer valances till later. I'll be doing a lot of work further up, and don't want to fill the gap
with debris. But at least I know they'll fit OK.
Onwards............The screen was cut out. I was expecting to have to do some work here.
.........and wasn't disappointed then! Here's the first couple of sections pieced in. The weld line will be
(just!) behind the screen rubber.
There were a few localised pinholes above the N/S washer jet, so I jammed a copper sheet against the
back, and MIGed the holes up. An expensive way of casting sheet metal!
Now I've just discovered the limit of ten picsw per post, so I'll copy and paste the rest of this post into.........................
