That is glorious! What a great colour scheme
This is what I need to get onto with Betty, where abouts did you source the aluminium, I was thinking about using Alupanel which is like the composite stuff that is pre coloured. I was going to go 3mm both sides just to ensure its solidFor a long time, I've wanted to replace the lower panels of the coachbuilt rear of the van.
Out of the factory, the panels were 1.2mm Aluminium, but the drivers side and half of the rear were 0.5mm (thin enough to wrap a turkey), as a result of a shunt back in the distant past. Added to that we (me actually) had made contact with a big rock sticking out of a welsh drystone wall a couple of years ago, so it was a job that needed doing.
So.....
Off came the nearside panel, and......
The rear panel with that dreadful toilet window had to go. Followed by.....
The lower half of the door which had rotted through at the bottom due to being in contact with the steel part of the frame.
Generally the timber framework was in remarkably good nick, but I reinforced many of the joints with brackets, and renewed wood where necessary. Several hundred stainless steel screws, and a load of panel adhesive later, here's the new panels fitted......
I warmed up the barn with one of those diesel powered space heaters so that the panels were fitted warm. That should avoid the panels going slack in the summer, should the sun ever shine. The side trims took a lot of straightening, as they had been badly abused in the past. Lots of screws in those too! You should see the motley collection of screws that I took out, many of them builders drywall screws, now stainless raised countersunk slotted heads for all those in view.
I've still got the nearside panel to final fit, but it's all cut out and clamped in place, ready to do next week.
I just found an aluminium sheet supplier online, and they delivered next day. Most cities have one.This is what I need to get onto with Betty, where abouts did you source the aluminium, I was thinking about using Alupanel which is like the composite stuff that is pre coloured. I was going to go 3mm both sides just to ensure its solid
Thanks so much for this, will let you know how it goes when I finally finish the timber workI just found an aluminium sheet supplier online, and they delivered next day. Most cities have one.
I'd advise against 3mm panels. They'd be heavy, expensive, and more difficult to fit. They would deform just the same if you hit anything. I reckon that the original 1.2mm (edited) is about right.
You can buy oversized standard ally panels. Mine were 3.5 x 1.2 M I think. That saves having a vertical join.
The important things are that higher panels overlap lower ones to shed water , and that you have plenty of the correct fixings, and use polymer adhesive like "Sticks like ****" on decent straight framework.
