OK. Time for some mud flaps.
Front and rears were both needed. Already there is a fair dollop of carp distributed over the underside.
Came back from the local truck services supplier with a pair of tipper truck twin wheel mudflaps. These are seriously tough pieces of kit as you can imagine.
Then cut each one into two 15inch by 10inch flaps. Just like cutting conveyor belt!
Fixed with 5mm self tappers and some building tie strip left over from the new garage roof.
Fronts, fixed behind the chassis outrigger.
.........and rears, fixed in front of tthe outriggers.
All with some bituminous goo behind to prevent corrosion.
I've also put 32mm blind grommets in any of the chassis holes which are in the firing line, to keep the dirt out, but leaving enough open to give ventilation.
I won't have to avoid the puddles any more.
