The timing idler wheel boss can float around so the backlash to the cam and injector gears has to be set with feeler gauges before the boss is tightened to the block.
The manual makes it look quite complicated, but once you get to do it it's straightforward enough. Each gearwheel has to have a couple of thou backlash to it's mate at any point of rotation. The crank gear had some scuffing, as evidence that this excercise hadn't been done properly last time.
Once the boss had been tightened to the block, the timing marks were checked again.............and again.
I particularly like the Perkins geared timing. No belts to snap or chains to break. Here's the timing marks lined up.
The tab washer was turned up and the cam gear bolts checked, then the temporary bolts were removed and the timing cover fitted. The oil seal is only months old so I didn't replace it.
Right. That's it for today. I'll finish building the engine tomorrow, hopefully. Feeling good so far!
