Dolly The Autosleeper
It would be better to mount it as far forward as you can in the cooler air, wont increase the length of the ducting and it'll keep the bends smooth as well.
Two's company
hmm, you just gave me an idea. if i cut just below that red line then the air filter pipe should be able to run straight over the rocker cover to the other side (if the bonnet will close over it) and then the k&n should fit snug onto the end with less of a curve. hmm
it definately seems like a strange su conversion. the carb comes up off the manifold and curves in towards the rocker cover. i wonder what the carb came off
I was toying with a Stromberg conversion ages ago and bought an adapter from Speedyspares. It was meant for an SU and unfortunately it held the carb too high and at the wrong angle for the Stromby - it could be what you have got.
Two's company
yh, sounds about right m8, but it soes seem to do the job, sounds nice and pulls well:). hopefully i can get it done tomorrow. my 2 year old has decided that dolly is HIS lol he comes out and sits on the chair "driving" why i work[^], today he found the button for the little air horn and pushed it;). jumped right off the chair then laughed his head off :D:D lol. when i took him in to his mum he kept screaming at the door til i let him come back out[:0]. thought i might attach sand paper to his shoes and have him run round in the back :D
Had another look at my air filter today. its huge so fitting it in the drivers side was very tight. in the end i moved the coil onto the inner wing to make just enough space. and made up a mount to attach it to the coil fixing. then whipped of the bend and had a little chop
afterwards i filed it to shape a bit and re-fitted it. ended up sitting just right, slipped in a bit of pipe and hey presto
once repaired the bonnet should just fit with a small gap. i think it looks spot on :D only 1 slight curve in the pipe and the pipe is only 6 inches long ;) well done for the idea's boys :D
Nice one Paul[8D] That electrical box you mentioned looks like an electronic ignition module to me - is it connected to the dizzy in any way?
Two's company
to be honest i havent traced the wires yet m8 but i will look tomorrow and get back to you. electronic ignition module? would that mean i would not need the kit off ebay? snug is the word m8. when i say it just fits i do mean JUST lol
If it's connected up and working then you won't need anything else[8D] Have you had the dizzy cap off?
Two's company
i did briefly but i didnt really pay much attention as i was intending on putting electronic ignition, cap leads and plugs all at once just whipped off the rotor arm to clean it up a bit and cleaned the terminals in the cap
Hmmm, if it was lekky ignition the shouldn't be any points but some sort of trigger.
Two's company
hmm, not sure on that one m8, i will look why im out there tomorrow, fingers crossed eh. as it happens because of where i put the filter the rad fan kicks alot of cold air its way. cant see it in the pic but i have also run a cold air feed from in front of the rad to a couple of inches in front of the filter. but i will need to remove the filter to check my ignition. will look at it and take a picture lol stopped that slight squeek from the engine and found a funny earth problem in my rear indicator today as well
All the bits you're doing are adding up to a lot of work, well worth it[^]
Two's company
The red wire coming from the coil is encouraging, or did you fit it:I
Two's company
yh, im pleased with what ive done so far [^] lol, but its great being able to chat to you guys and get opinions and advice;). tim is holding some floor and an inner wheel arch for me:D, colin sorted the air filter:D. before you know it ill be having to arrange a meet just to buy you all a bevvy :I lol im waiting for the ground to dry so i can get underneath and try to work out exactly whats needed[B)], got a feeling it needs at least 3 outriggers, and 2 spring hangers[:0]
didnt fit it mate, just put a new terminal on the end;)
It's easy to make your own chassis sections, I did all mine on the B&D Workmate and a couple of legths of angle iron:)
Two's company
would that go for outriggers as well?
how did you set the angle iron up for bending m8
