Originally posted by thowman
Originally posted by Beachboy
If your PA has its original engine then it will be a 1500cc unit and it should have a Solex carb fitted not a Zenith or any other make!
if it has a Weber then I will bet it is jetted wrongly because Weber never did a carb for the 1.5 Commer/Rootes engine.quote:
I guess it also doesn't help that I don't know what size my engine is..... being a PA with the original engine. I might find the engine is a 1500 and have a carb jetted for a 1725!
Bloody Commer`s!
Well, there's the conundrum. On all the original documentation have: the original Green logbook - it's capacity is listed as 1725. However, on the modern V5, it's down as a 1500 - go figure. It's a late PA, registered in May 1967 - and I believe the PB was introduced soon after?
Anyway, aparently the later PA's had a 1600 unit fitted. I guess without dismantling the engine, I am not going to find out the capacity.
I think it's been listed as a 1500 on the V5, because the van description in Commer 1500 wanderer, and that mistake was made when the records were computerised. Having spoken to Martin, he thinks it might be a crossover vehicle between the two?
Bloody Commer`s!
