JavaScript is disabled. For a better experience, please enable JavaScript in your browser before proceeding.
You are using an out of date browser. It may not display this or other websites correctly.
You should upgrade or use an
alternative browser .
Tigger's Bouncing!!!!
Good work, Colin !
1965 Commer (1592ccm) series IIa Bluebird Highwayman
Well, I made a start at least......only had an hour before the heavens opened up and stopped play
The old Weber...
Got the manifolds and exhaust bolted back on, then realised the rain was pouring off the roof right down my legs ...
Nice one Colin, the hard work is done
Off to a flying start
So, now I need help please..
I guess 1, is fuel ...2 is vacuum ...but what about 3??
Left being 1, 2 middle and 3 right
and the throttle cable goes here? so where does the choke go?
Float chamber overflow
No.1 is fuel feed, no.2 is a breather, no.3 needs to be blocked up, a bit of hose with a bolt clipped in will do it.
Looks like you're missing the little cable clamp for the choke.
The bracket with the three holes operated the choke, there is normally a nipple on the left hand hole to clamp the cable. You will also need some method of clamping the outer cable - check out 'Mini abutment plate' on ebay.
What is the hose for that goes here??
You don't need it, there is a vacuum connection on the carb
So just to make sure.. 1 is fuel intake... 2 is for the vacuum hose to dizzy and 3 needs to be blocked [?]
You may be able to see fom this pic
Vacuum hose to dizzy is the small spout that sticks up vertically near the mounting flange
Thanks for the pic John, that makes the choke seem easier now I know where it should go[8D]
I didn't get round to following the hose from the manifold back to see where it went, but its fine just to disconnect it?
Unless it's connected to a brake servo, is there one fitted to Tigger?
As Tim said, use the small vac connection near the flange and block off the other one. Leave the overflow open.
The missing link http://www.ebay.co.uk/itm/CHOKE-CABLE-RETAINING-PIN-AUE34-TRIUMPH-SPITFIRE-SU-FREE-UK-POSTAGE-/230860582789
Thanks John and Tim.....don't now how I'd manage without you guys[8D][8D]
I have no idea if Tigger has a servo John, I will follow the pipe in the morning....
you need to repaint your rocker cover to be closer to "iron man"
