Hi all
Been off the electrics since the last update, the oil cooler, hose and fittings arrived and got stuck into getting that sorted. With most of motor and accessories in place in the engine bay it took a lot of experimenting as to where the best place for the remote oil filter, plus planning where the hoses to it from the motor and then the run to the oil cooler need some very deep thought.
The first drama that needed to be resolved was the actual remote oil filter kit. The remote filter part that is fitted to the engine has a choice of imperial or metric. The Nissan Z24 motor takes the imperial thread, so that was quickly sorted. Unfortunately there was no option with the remote filter body, it had a Metric M20 tread. So a quick hunt on the web and started checking the Ryco filter catalogue. eventually found some Renaults had M20 filters, noted the number and headed off to Supercheap Auto. Once there I found the filter and discovered this tiny little thing, yes it had a M20 thread, but was about 2.5" diameter and 1.5" long! The fuel filter on my 2.5pi Triumph is bigger, so started hunting through the catalogue hanging from the shelf and eventually came across an unlikely donor, the Rover 416i (yes I know it's a Honda we had them here too). They seemed to have been made with both Metric and Imperial threads, and the filter was compact, compared to the huge old Z9 filter and probably twice the size of the Renault filter, SOLD!
Now with a filter fitted to the remote filter I could spend endless hours holding it in different places and positions in the engine bay thinking about where and what the oil would leak over when doing future oil filter changes and if I could actually get my hand to it or oil filter spanner if necessary and the spaghetti of oil lines each position would create. Stressed I decided to have a look at positioning the oil cooler, surely that wouldn't be too difficult, wrong again! After loosely re-assembling the steering arms etc, it became obvious that the passenger side was pretty straight forward ,but the drivers side has the mounting for the steering relay assembly in the way (insert colourful language here). Having a closer look it wasn't insurmountable and thought a couple of spacers and longer bolts on the lower steering relay mounts would be fine. The spacers were easy, Triumph saloons have spacers about 1.25" long between the g/box cross member and the body mounts on the automatic models. I converted the 2500pi Estate and a 2000 saloon to manual years ago and the spacers were in my bucket of nut & bolts. While working on the cooler mount it occurred to me there is plenty of space above where the oil cooler will eventually be, why not mount the remote filter above it, out of the engine bay, forward of the radiator. I checked positions and oil hose runs and got to work.
This is the cooler mounting with the cooler & remote filter roughly in place.
The Remote filter fixes to 1.5" angle, cooler isn't quite lining up at this stage, but a few adjustments and it was much better.
Here it is now in place in the van
Since this shot I have made a top mounting that picks up the top of the angle and bolts to the marked bolt/nut that holds the gear lever assembly in place. The short hose from the remote filter to the cooler is short, but the whole assembly is quite ridged and the shold be little or no movement to put load on the fitting or cooler.
Now with the hoses from the motor connected to the remote oil filter and cooler.
The hoses from the motor will run through the space between the side of the radiator and the body work. Will sort out some mounts/clips to hold the hoses in place.
A view of the Remote filter.
Oil Cooler kit came with 8 hose fittings, 2 straight 2 x 90deg bends, 2 x 45deg bends and 2 x 180deg bends, though I would never use the 180's, very glad they were included. You can also see the Oil pressure gauge/warning sender unit, single unit sends signal to the oil pressure gauge, with a second terminal for the low oil pressure warning light. The oil temperature sender is hidden from view. Now they are in place I can work out where to run the wires for them.
Looking underneath from the front
The circle shows where the bracket had to be spaced out. Spacer only fitted to the rear bolt in this shot, you can see the other sitting on the block of wood under the cross member. I was originally going to use the lower set of bolts, but remembered the sway bar after I had made the initial mounting, then discovering they would fouled each other, so moved to the upper set. Cooler is set back so cool air can still travel over it to the radiator. Having it set back also gave me the space above for the remote oil filter location.
So that's another job done, have now contacted Miss Piggy's Rootes parts mate in Queensland about a 2nd hand radiator and hope to get that organised and shipped next week. Unfortunately daylight saving ends next weekend 11/12 April, which will make it a little difficult working on the electrics in the afternoon after work. The van is outside the shed and have got my fluoro work light ready to go, so will push on and light a couple of mozzie coils and see how things work out. I planned on making the most of daylight saving this year and extremely happy with where I am now, considering I only re-commenced work on the van once I had relocated it at the beginning of December
Cheers for now
Stephen
