Hi All
With the exhaust system out of the way I took some bravery pills and started looking at the wiring. As mentioned earlier I have removed the wiring loom from my "spare" Mk2 Triumph 2500pi in the hope I can utilise this, with its additional features in the Commer. Well, so far so good. I unwrapped sections of the loom so I could reposition various wires so they could be positioned to suit the different layout in the engine bay. As it has come from a car, quite a few of the wires will need to be shortened, and only a few lengthened. Looks a bit like a colourful spider web at the moment, but it does make sense.
The Black circle shows the small panel from the Triumph that locates the fuse box, with 4, yes that's 4 fuses! This position in the Commer is basically the same as in the Triumph, and there are threaded holes in the internal rib that I will be able to use, most likely there for the regulator and fuse on LHD Commers.
The wires in the red circle that come from the fuse box are for the rear of the car and will connect up where the existing rear loom starts. I might change that over eventually to the Triumph rear loom as it has a few extra wires, like half way along is the connections for the Roof cabin light, then to the rear there is wires for the electric fuel pump, heated rear window demister, boot light, low fuel level & fuel tank sender, but will stick with sorting the front for now.
The wires in the green circle are those that go to the Triumph centre console, Cigarette lighter, 2 speed fan switch, switch for the heated rear window demister, choke on warning switch. I think there's a power feed for the clock here too. One wire to relocate in this group is the handbrake warning light switch, which should be pretty straight forward, just need to mount a switch on the handbrake.
Below the Green circle are the cables for the engine bay. I have split this group so in the blue circle we have the wires for the Ignition coil and resistor, tacho and water temperature sender. The group of wires that will travel down the other side of the engine bay will be for starter motor and solenoid, alternator, Low oil Pressure switch. Down this side I will need to add a few wires for the oil pressure & Temp senders and a power feed for the thermo fan.
Lining up nicely behind the steering column, unfortunately obscured by the cigarette lighter and other wires are the 4 loom connectors for the column switches from the Triumph I fitted earlier, including the ignition switch, headlight main switch, indicators/hi-beam and wiper/washers/horn.
The smaller white circle shows the 3 loom connectors for the instrument panel loom.
There is plenty of length on the instrument panel loom and will need to shorten many of the wires this loom carries the usual wires for instrument lights, fuel and water temp gauge, Hand brake warning light, low fuel, low oil pressure, hi-beam warning, and ignition warning lights. The bonus is that it also includes the voltage stabiliser which I will need for the original fuel gauge.
The loom continues under the dash to the driver side of the car for the wires that run to the headlights, indicators and horns. On the Triumph it exits under the driver side "A" pillar and runs forward then across the front to all the light etc, and is about 12 feet long, so plenty to play with there.
Just another thing, I was thinking about the front indicators, as mine is an early model with the single clear combined park/indicators. With the proliferation of LED lights available these days, I jumped on to ebay and had a look about and found these combined white/amber globe replacements.
How cool, I can have clear parking lights, which flash amber when turning. I found some for sale in the UK for $20 each + another $20 delivery. I then looked further and found someone in the Philippines selling them for $2.60 each and $2.75 postage for 4 globes to Australia. It's a crazy world we live in these days! Ordered the 4 globes and they arrived safely about a fortnight later. Here's the link if any one is interested
http://www.ebay.com.au/itm/New-12V-BAY15D-1157-60-SMD-White-Amber-LED-Light-Bulb-Car-Tail-Brake-Signal-/121553809976. I have been told that I might need to install a resistor in line so the flasher can works, but hopefully if I leave the rear indicators and tail light globes as standard, that might be enough. Plenty to do before then.
That all for now, will keep plodding and update as things progress
Cheers Stephen
