After having the van sitting in the front garden with no front suspension I had a brilliant thought. Make a draw bar that I can fit to the front of the Commer so I can hook it up to my other car and relocate to the driveway so I can get some work done. Well after a lot of thought I elected to bolt the draw bar to the steering arm mounts at the front of the chassis, fortunately there are 2, for RH & LH drive models. with a weight bearing section across the front chassis rails behind the radiator inlet. the A is 75x50mm (3x2") steel box section 1.5 metres (5')long fitted with the usual tow hitch.
So once hooked up away we went and she's now relocated to the drive in front of the shed. I will be making a small modification so lifts it a little higher as the draw bar dragged a little going over the rise in and out of my driveway. If it was dead flat clearance wouldn't have been a problem. Since the move the van has had a good wash and light polish to give the paint some protection and looks much better for the attention.
The blue tarp covers the back as there are no rear windows. I cut some templates out in some thin Perspex I had laying around and with most likely have to have some cut to suit as I cannot imagine anyone in Australia having replacements, (Any of the Aussie crowd out there have a couple Spare they don't need??)
Just in case can someone advise the height, width and thickness of the original rear glass. I will need rubbers too, but will check out the local suppliers first
Next I want to clear out he front of the cabin so I can start working on getting the Nissan Z24 & Urvan gearbox in position and seeing what mounts need to be made.
Just looking back at this thread and shocked it is over 4 years since I got the van.
Cheers Stephen
Cheers Stephen
