Right well seeing as i have been wanting to convert to discs and my front subframe is off, i thought i had better start a thread for reference so people can see what can and can't be done as i experiment to try and find a solution! This will be a front and rear conversion, taking into account that the front will no longer have a handbrake and the rear will have one instead.
So far i have the front drums off, the 4 bolts that hold the drum on are perfect for holding a caliper bracket, and the hub itself seperates from the drum so it would seem with some lathe work, and maybe a spacer, a rotor with the correct pcd will slot right on and not push the wheels out any further (from what i can remember, there is only an inch of room between standard tyres on 15" wheels and the body when on full lock)
I am aware the humber (can't remember the model) brakes fit, however these are like hens teeth and more than likely to be not much of an upgrade as well as getting hold of parts later on being an issue.
So with this in mind i have been hunting for 5x127 pcd cars to steal rotors from, which is proving difficult!
This link shows a range of car pcds:
http://www.carlsalter.com/wheel_fitments.html
The Jeep Cherokee 99> is the only car listed and seems a pretty good start, but i can't seem to distinguish which rotors i need as most sites do not mention the pcd of the rotor and i know not all of them were definately 127mm...!
I know some rovers came with 5x127mm, but i keep forgetting which ones, so if anybody could fill me in on that, i would appreciate it greatly!
I am still yet to decide on calipers, i have bmw 3 series, golf mk3 and saab 9000 calipers to hand, but i feel that maybe i should hunt for something a little larger such as a transit or cherokee caliper? The only trouble i can see with running these is that they may be too large for the stock wheels (which i intend to keep). The saloon car brakes may well be good enough seeing as the commer won't exactly be travelling quickly and the weight isnt super high even when loaded.
Any feedback and help would be much appreciated, i really want to get some momentum on this before i go back to uni, and hopefully give other commer owners a starting point for a brake upgrade when they do engine swaps! Please bare in mind that i have not done this sort of thing before, and have only got what i have read on the internet to go by, so excuse my naive approach
Anyway, i shall have photos to upload as i go, im now going to pop outside and drill out my spare 5x120mm bmw rotors to fit to mock up how it should look and fit
