The Disc Brake conversion thread
Right well seeing as i have been wanting to convert to discs and my front subframe is off, i thought i had better start a thread for reference so people can see what can and can't be done as i experiment to try and find a solution! This will be a front and rear conversion, taking into account that the front will no longer have a handbrake and the rear will have one instead.
So far i have the front drums off, the 4 bolts that hold the drum on are perfect for holding a caliper bracket, and the hub itself seperates from the drum so it would seem with some lathe work, and maybe a spacer, a rotor with the correct pcd will slot right on and not push the wheels out any further (from what i can remember, there is only an inch of room between standard tyres on 15" wheels and the body when on full lock)
I am aware the humber (can't remember the model) brakes fit, however these are like hens teeth and more than likely to be not much of an upgrade as well as getting hold of parts later on being an issue.
So with this in mind i have been hunting for 5x127 pcd cars to steal rotors from, which is proving difficult!
This link shows a range of car pcds:
http://www.carlsalter.com/wheel_fitments.html
The Jeep Cherokee 99> is the only car listed and seems a pretty good start, but i can't seem to distinguish which rotors i need as most sites do not mention the pcd of the rotor and i know not all of them were definately 127mm...!
I know some rovers came with 5x127mm, but i keep forgetting which ones, so if anybody could fill me in on that, i would appreciate it greatly!
I am still yet to decide on calipers, i have bmw 3 series, golf mk3 and saab 9000 calipers to hand, but i feel that maybe i should hunt for something a little larger such as a transit or cherokee caliper? The only trouble i can see with running these is that they may be too large for the stock wheels (which i intend to keep). The saloon car brakes may well be good enough seeing as the commer won't exactly be travelling quickly and the weight isnt super high even when loaded.
Any feedback and help would be much appreciated, i really want to get some momentum on this before i go back to uni, and hopefully give other commer owners a starting point for a brake upgrade when they do engine swaps! Please bare in mind that i have not done this sort of thing before, and have only got what i have read on the internet to go by, so excuse my naive approach
Anyway, i shall have photos to upload as i go, im now going to pop outside and drill out my spare 5x120mm bmw rotors to fit to mock up how it should look and fit :)
Go for it Paul, pioneering stuff[^]
Summer's here.....
So they say
Cheers Panky :)
So it seems the hubs are too big to fit in the rotors i have spare...
Fingers crossed the correct rotors i find will be big enough, as i dont think i can get away with lathing down the hub too much...
From what i have seen, Rover SD1 hubs are similar looking and size, but the rotors are only 256mm, i was hoping to be around the 290mm area ideally
Have you seen this Paul?
http://66.129.69.181/forum/topic.asp?TOPIC_ID=4472
Is there an equivalent big British Vauxhall
Summer's here.....
So they say
I had seen that thread at the early stages, but did not relaise he had gotten any further! I do not seem to be able to find anything like that as a donor, and i do not want to change the PCD, i want the commer to look pretty much stock from the outside, but with some decent touches underneath. I think The jeep/rover rotors are seemingly the best way to go so far as they are available easily :)
Ive got some humber hawk front hubs and mounts.I was planing on fitting the hubs being identical to the commer mounting points and putting bigger discs, calipers on them. As the hubs are already meant to take a disc shouldnt be to hard to put a bigger one on. Havent really looked at it much though,one for the future;) How about some volvo calipers?? thats what "HUT" runs;)
Rotors? C'mon, this isn't America, they're discs!:D
Spare a Commer Guv?
Yeah i knew the humber stuff would be a direct fit, although will you not have to it a rear handbrake? Also you will still need to make bracket adaptors for the calipers, so you may very well be better off going my route (if it works out) and making some money out of the hawk stuff seeing as i bet the owners will pay a small fortune for them!
Yeah i keep saying rotors rather than discs because i am on an american Saab forum rather alot, luckily i have not started calling bonnets hoods and boots trunks!
Im aware I will have to make a caliper bracket but having a quick look at it should just be a straight forward, straight bracket. You can fit fast back rapier rear cylinders in the rear back plates of the back axle,this means it will give you a hand brake lever hanging out the back of it to connect a handbrake all you need to do then is find a very long cable and make some mounts up for it. But if your doin discs all round you will have to use a rear caliper off something with a hand brake mec built into the caliper;)
I am going discs all round and my rear caliper has the handbrake built in, but thanks for the info:)
A quick measure up revealed that the discs need to be around 280mm to allow the caliper to clear the standard steel wheels.
Jeep 305mm discs have been ordered, £55! They should arrive at the shop tomorrow and if they are correct, then we can get on with seeing if they fit up onto the hub and what will need lathing (the rotors will be lathed down to 280mm or whatever is correct. The hub will need a small amount removed for the disc to sit flush against the hub, or the centre bore of the disc will have to be increased)
I popped into a local garage, of which i know the owner has done many conversions in his time, he seemed happy with what i was doing and said my Saab calipers should be more than man enough. Once i have the discs machined, he will help me decide on the design of the caliper bracket to ensure it is sturdy enough [8D] the local fabricator has a selection of thick steel plate that will be perfect for the job.
For the rear of the Commer, i am going to source either some Jeep rear dsics, or Rover SD1 front discs as they are both solid rotors, so my Saab calipers should fit over nicely. I will also need to make caliper brackets to weld onto the rear axle housing.
I will be using the Saabs master cylinder and servo to match up to the calipers. Looks like there will be a complete commer brake setup up for sale soon if anybody is interested!
SD1 vitesse had vented discs :)
You could go for some discs with bolt on centre "bells"
These are Subaroooo ones to go on our Riley. Plan is to unbolt the centre and machine new ones with the correct pcd and offset to fit on the existing hubs. Then its just the caliper carrier to make :)
You may also need a bias valve as its likely the rears would lock first ;)
When we hunted through the catalogue, we could not find anything other than solid! I will keep them as an option if the Jeeps do not work out though! The trouble with those bolt on centre bells, is its just another cost on top really, i am trying to do this with a lower budget in mind, but thank you for the suggestion!
Regarding bias valve, i was going to use the Saabs one, would that not be ok to do seeing as the Commer will end up with pretty much the same size discs and will be using the rest of the saabs braking gear?
Thanks the link to "The New Project" and some action on brake upgrades. My reasons for going to six stud were an accident really. I managed to get the Navara diffs so cheap it was worth a try and is now installed in the van, plus there are so many Jap utes and vans with 6 stud hubs i thought the odds would be better as 127PCD hubs are like hens teeth here plus 6 stud mags are easy to find and reasonably priced.
The weather is starting to warm up now so i'll be getting back to the van and getting the front end sorted, which will probably end up with 290-300mm vented discs. I had my eye on some hubs recently, but the wrecker squashed it before i had a chance to check them out. You've got to be quick!
As for the rear brakes, I can live with the huge Nissan drums with the bonus of a LSD and 4.375 diff ratio. I have been told that the rear discs off a Nissan Terrano bolt straight on, maybe later.
Interestingly our 1980's Holden Commodores have exactly the same bearing sizes but are closer together, unfortunately the diff and wheel offsets wouldn't have worked for my budget.
Any information is good information, will update as it comes together.
Cheers Stephen
Thanks for replying Stephen!
I am wishing to stick to the commer pcd, this appears to be my major downfall right now though! I may end up following a similar route to you though...
The jeep rotors arrived, they fit snugly onto the hubs which is nice. They need 5mm worth of spacers to sit correctly (currently using washers for assembly purposes).
The rotors are of course, far too large to sit under the commer wheel.
Due to the nature of the wheel centre with its stiffening buldges, this stops me fitting any more than around a 260mm rotor (so maybe smaller vitesse discs will have to be an option) as the caliper catches this buldge. These jeep rotors would have hardly any braking surface left if i were to do this.
Here is a 290mm bmw rotor and caliper in the standard wheel to show how even that is too large when sitting agsinst the wheel centre, but very close to being correct:
The 280mm saab rotor and caliper was super close to being correct
A way to get around this size issue is to space out the front wheels by approximately 20mm (this plus the disc spacer would of course i would need longer wheel studs). This would then allow for the caliper to clear the buldges and have more room, allowing for aproximately a 280mm rotor overall. I think there is an inch of room on full lock between the body and the wheels as standard, and i may be able to reshape the metalwork to gain some small but useful clearance! It does not look like i will gain a significant amount. Also with my intention of running lower profile tyres, this should also give me more clearance. Another bonus to this is that a widened track would provide what seems like much needed stability to the commer at the price of putting more pressure on the wheel bearings.
With this spacer the brakes would sit here roughly, and would need to have 5-10mm off them for decent clearance
A stepped caliper mount will have to be made these photos show that with the spacer, the hub face and caliper bracket are basically in line.
To put it simply, i am stuck and don't know what im doing haha. Input would be great!
You are doing something, which is what matters [^]
Why not use SD1 wheels, then you will have more caliper clearance ;)
I really wanted to keep the commer wheels, then get them banded! But i shall keep SD1s in mind! Are you sure they will have more clearance?
I found these:
http://www.ebay.co.uk/itm/Rover-SD1-Fondmetal-Alloy-Wheels-/250886465188?pt=UK_CarParts_Acc_Wheels_tyres_Trims_Car_Rims_ET&hash=item3a69ffa6a4
which look tempting as they are quite nice!
On the standard wheels, I tried some cavalier 256mm discs and calipers...still not enough room unless spaced out! After much messing around with washers as spacers i found that i need a 20mm spacer between the disc and the wheel, and a 5mm spacer between the disc and the hub (so that a thick enough brake bracket can be fitted) which meant that with the standard jeep rotor i was only just scuffing the rim. I have 7mm between the pad edge and the disc bell, so if i get 10-12mm overall taken from the disc size, i should have enough clearance each way without limiting pad surface area :) i think its going to be one of those things where i need to start removing materila to work it out as its become a bit of a balancing act right now!
Now, where do i get longer studs from? i hope to swing by the garage and see what the dude thinks of my progress so far, then swing by the local rally place and get some wheel spacers :) once they are fitted, i can have the disc lathed down and then its mount making time!
The caliper clearance is always an issue. Get hold of an alloy/mag wheel as they often offer greater clearance. I used to run 260mm vented discs on my Datsun 1600 rally car. They too wouldn't fit with steel rims but cleared when the right alloys were used.
The Calipers look very bulky on top, which is also adding to your problems. The Holden Commodore calipers that i am using are alloy single piston, I also used these on the rally car for that same reason. They were also made for GM USA and used on the Corvettes in the 80-90's so you might be able to find some in the UK, but there should be something similar locally for you.
I will post a picture this afternoon, unfortunately I need to get off to work.
Cheers Stephen
