Hi all
Back again to update what’s been happening. I thought I should start looking into the hydraulics of the braking system, seeing as the brakes are now pretty much sorted. Firstly I got hold of a set of rubber brake hoses from the same model Commodore that I got the disc callipers from. They should be long enough and have the correct banjo fittings for the callipers.
I will be replacing the original fixed steel brake lines as they have seen better days, plus they go to the wrong place as I will be running the callipers in front of the front axles. I still need to check the sizing and flaring arrangement for the other end, but all in good time.
I did a little research on the Commodore braking system and discovered they have a dual sized master cylinder. Apparently due to the need to displace such a large amount of fluid for the front callipers compared to the rear callipers the master cylinder is made up of two differently sized sections. The section that is for the front brakes is 1.25” bore and the rear 1” so everything should be fine for the front brakes, but when checking a Navara for my rear drums, I found they used a 15/16” master cylinder, so I might need to find some larger cylinders for the rear drums, more homework!
The Commodore brake master cylinder is quite compact, rather than being one long cylinder with two pistons one in front of the other, it does a “u” turn and comes back with the different sized cylinders next to each other.
I hadn’t seen this before, but it solves many of the problems that I had anticipated. The reservoir is a little too tall, but it is easily removed and should be able to be modified to a remote reservoir set-up. Most importantly, for a dual system master cylinder, it’s only about ½” longer than the standard Commer unit. I will need to weld a larger flange plate to the Commer mounting bracket with new fixing holes and open the centre hole from 1.25” to 1.5”. The Commer piston actuating rod will fit, with a couple of fiddly mods to make me happy.
The best news of all was the prices. The brake hoses cost $22 a pair and the master cylinder, which I’ve seen advertised for up to $200, cost just $35. Yes they are second hand, but came off a car around 5 years old and will have many years of service left in them.
The last things on my “braking list” to be investigated are a suitable remote brake booster and a load sensing proportioning valve for the rear brakes. The remote booster may need to be a new unit as there are few, if any cars in the recent past that have them fitted. The rear load valve will be easier, most Jap utes and vans have one fitted, but might start by looking at the Navara unit to match my diff/rear drums and keep the rear brake line threads consistent. I recall seeing that some of the later Commer/Dodge vans also had these fitted and think it worth including after all the other work that has gone into the overall braking system in my van
So that’s the plan, now just a case of getting it done.
Cheers Stephen
