ported exhaust manifold
Make a official complaint, in writing, and send it to Chris ;)
Another one well on the way :p
This gives you an idea of just how much weld is needed to get a decent port shape [:0]
Hello Martin can i ask what throttle cable you are running with your big su as mine doesnt open the carb much it just twists the rod running across the van, or have you removed one of the two return springs from the carb spindle[?] Also are you putting the panel back over the top of the carb and where is your airfilter now living[?] Thanks, Nathan
I'd rather have a bottle in front of me than a frontal labottomy!
here it is martin :)
new flange welded on :p
with 4 stainless m10 studs [^]
new 1 3/4" o/d downpipe bent up, with the latest cutting edge sealing technology................. a BSA bantam exhaust ring :I
and the whole thing assembled [8D]
inlet tomorrow ;)
Tim
Are you still doing these manifolds and if so how much do they cost? Debs has a 1600 engine in Brian, but we have a spare 1500 exhaust manifold will this fit a 1600 as we could get that one modded if your still doing them.
Dave
Yes Dave, still grinding away [xx(]. can do something for you ;)
Cheers Tim, will get the spare manifold off the engine and Deb will be in touch re getting it over to you.
Thanks
Dave
Hi there commeracer, I was wondering if you were still offering this service and if so is this part fairly easy to remove, many thanks j :)
Well, yes and yes :)
6 bolts hold it on, exhaust and carb off and that,s about it.
Thats great, also i want to fit a rc40 exhaust so what extra bits would i need to order to make it fit and would you be able able to modify it for me :D (at a fee of course)..
Hi jagger you will need rc40 back box - mid section and fitting kit I went for mild mid section and stainless back box you will find this all on www.minispares.com
GOD DAMN IM MISSING MY VAN.
BUT IT'S GOING TO BE WORTH IT
Thanks Rich-Lou just gave them a bell and the gent said if i bought a maniflow system it would'nt need any mods is this true or if i bought rc40 what extra tubing do you need, many thanks for your patience i'm a carpenter not a mechanic:D
No prob I'm a builder myself and only know limited stuff. I'm not sure about maniflow system to be honest and as far as I can remember when mine was fitted no extra tube was needed but it requires lots of chopping and changing and welding together none of witch is a problem for Tim ( commeracer )
Cool .. Ha ha ha tims busy fitting my engine he ain't got time ha ha I'm sure he will be along soon to answer your needs
James, you don,t want a Maniflow system, as Rich says, just the RC40 middle and back boxes and fitting kit from Minispares. It just needs shortening and an adaptor sleeve to step up from the original down pipe, no extra pipe needed. I can do it all for you,but need the van here (Norfolk) :)
Ok james just seen that your a new member so welcome along get yourself on chat say hello and get some pics uploaded of your motor you will find all the help you need with your van projects
Hi James and welcome to ze Madhouse:D
An RC40 is a good mod and with an SU conversion a brilliant one, you'll tell the difference immediately[8D]
Two's company
Well thank you every one.. i was on here before but was working in france for a while and lost touch, forgot password and so on just got back on, dont mean to sound a bit slow but whats an su conversion? also norfolk may be a bit far for me im on the south coast i think i may have bought an petrol tank from you about 18 months ago.. If i remember commeracer uploaded some photos for me page 19 o0n readers rides chameleons autosleeper.. take a peak..:D
One of these
More of Tims handywork a few pages back in this thread, Inlet manifold is modified to take an SU carb[8D]
Two's company
