I've now got all the bits together to fit an electric fuel pump, in-line filters and re-route the fuel line. Might have to borrow thw ramps again for that as the pump has to be near the tank.
Ah yes, the tank. A week or so ago I said it was leaking. Well, having looked at it I now think it was leaking form the filler or overflow as the fuel was coming out close to the filler rather than near the tank. The tank itself looks to be in good shape. Think I'll have to fill her up again and try to see where the fuel comes out. So I probably won't be needing a new one just yet (sorry Tim).
I had the fuel evaporation issue again yesterday and while I waited for it to cool down I looked at the temps of the various components in the engine bay. The biggest problem with heat is clearly 'heat-soak' from the exhaust manifold to the inlet manifold which in turn will heat up the carb. Without a major change of carb and inlet manifold set-up there's not much to be done about that so let's hope the leccy pump etc helps.
Today I tidied up a bit more under-dash wiring sorting out permanent feeds for the radio and also for the engine cooling fan - so if I stop after a hot run it will run for a few minutes like a modern car does.
Then the sun came out! So I quickly opened up the trailer-tent and removed all the camping stuff and put it into Peggy ready for our first overnighter at the end of the month. Even got the tent put away before the rain returned.
Gave the kitchen bits a proper once-over and discovered that although the fridge is a 3-way there's no gas attached so just 12v or 240v. The electrics are a bit of a mystery at the moment! Connected the cooker up to some gas and the two hobs work fine.
Another job I've been meaning to do is fit Peggy's new black and silver reg plates, they're on now and looking cool. I've saved the old rear one to use when she's towing.
No pics today. Maybe tomorrow.
Peggy's got Sounds
