After first run out felt as if pickup was holding back. I removed the distributor and cleaned out the inside.
Distributor was full of mud and springs were Brocken. Refitted and pickup ran well. Set off for Moffat With a slight water leak but got to Moffat ok. Pickup ran great all the way to Moffat and nearly all the way back. Could smell burning on the way back then the alternator light came on. Alternator had seized. Got it back to the yard. Removed the thermostat housing and the alternator will refit at some point.
Pickup back on the roadthanks to Martin. Fitted new water pump thermostat and housing . Replaced all hoses. Removed old alternator. Fitted new alternator and belt.Had to rewired new alternator. Went for a run pickup ok
PICKUP Repainted the back bed of the pickup and put down none slip coating. Looks so much better.
POSTVAN refitted master cylinder and bled brakes. On the road again
AUTOSLEEPER Welding continues. Have now removed most of the paint from the van with just the roof to go the interior is being stripped of old varnish and rotten panels replaced hope everyone is well
Works van was off the road so pickup was drafted in to help. Made a delivery to carron foundry.The gates behind the pickup are from The International Exibition of Industry,Science,and Art held in Edinburgh Meadows in 1886
