So i finally got the gearbox, engine and front subframe out
Gearbox oil was pretty sludgy, but minimal metallicness to it, so hopefully its ok. There is a small bit of play (1mm ish)on the input shaft...is that normal? Or should i be looking at replacing the bearing there? There is either a seal gone there (although the gearbox seemingly had plenty of oil) or at the back of the engine as the clutch housing was lined with oily residue. I have not really had a close look at either of them yet to be quite honest!
Subframe, although greasy as hell, seems to be in excellent order! No wobbles, silky smooth, seems to have been well greased in its lifetime! Both springs look to be in good order. Shocks dont match, 1 is definately knackered!
Before:
After:
Engine:
Lovely rust and holes underneath:
So some degreasing, some rust removal, some welding, some painting and some reassembly is in order! At least that will be the front underside completed and i can then concentrate on the back
Before:
After:
Engine:
