While I am waiting for the new brake bits to arrive, I managed to get a jack tall enough to get the commer of the ground.....it took some jacking lol.
As previously mentioned, I have a solid brake pedal, and on further inspection, disconnecting the copper hose from the master cylinder enables the pedal to be pressed, squirting black brake fluid out...so I guess that this is functioning, although the system now has air in it.
I bled the brakes today and the solid pedal is back, so I thought I would crack off a bleed nipple to see if this eased the pedal......nada!!!
Next step was to disconnect the copper brake pipe to the passenger front wheel cylinder, and after applying lots of pressure to the pedal and using an Ezi-bleed, I got a few dribbles of nasty black fluid, but no where near enough. I have soaked the flexi hose unions and will work back from the wheels till I can get fluid. I am guessing at crapped up brake lines, as after removing the bleed nipple it was blocked with gritty debris at the master cylinder end.
I have made brake lines before for the mini, so will look into knocking some up.....any-one know if the unions are the same size throughout, and how much brake line I will need???
