BACK HOME!!!!!!!
A bit of a long trip for our first trip in a commer. Nottingham, Dawlish, Dartmouth, South Hams, a cracking campsite with views of the sea just outside Marlborough called Krageen, The Cornwall, Newquay, Padstow, Rock etc etc, Then on to Abergavenny to meet up with the rest of the guys on here, then finally back to Nottingham via the scenic route.
The bad bits: Over heating on the way down there, New starter, 3m of fuel pipe for re-routing, Missing throttle pin, 1 dead coil and a dead rotor arm....oh and the alternator mounting bolts went missing!!!! Limped into Newquay, met up with car minded friends at the Riviera Run, and spent a morning on her, turned the plate underneath upside-down which now directs cold air to the engine, which has made a heck of a difference...in fact on leaving newquay I could only get the temp up if the electric fan was turned all the way off.
My brakes were really tested on the run through Brechin with the rest of the commer people.
After some umming, ahhing and chin scratching it transpires that we have a non overdrive rapier engine fitted, good news, I can get a haynes manual and get her running sweet now!!!
he good bits...we love her, and after 2 weeks in her can start thinking about improvements:
I have seen a Willwood Tandem master cylinder that looks a good fit, this will give me some peace of mind, as I find dingle line systems a bit scary lol.
Get the engine tuned up
Have a look at fitting a couple of SU's, I am sure I have a couple of HIF38's, and the manifold looks like it may fit.
Make, fudge a new twin downpipe, the current one hangs really low.
Sort a new exhaust, Panky though we had a metal water tank slung underneath till he realised it was the back box...it's fri**ing huge!!!
These will all be running repairs as we want to be using her as much as we can over summer.
Long term plans are to tidy the paintwork and body work up.
I mentioned to a couple of guys at Abergavenny that an old school mechanic that I know has had commers in the past and has fitted sherpa front running gear, enabling disc brakes to be fitted up front, I will try and catch him and pick his brains.
