My Humber Super Merc
Super Smooth Bernie Booth (and friends) does it again!
Well done Bernie! See you all in Pandy.
Colin, it's not its original colour, fortunately. It will be returned to its proper blue at some point.
Top man bernie, I knew it was that immobiliser causing you all the agro.When I first started my job in the old days when there were loads of those mercs about they used to cause all sorts of trouble. I knew you would have her running once you had the correct info. Even goes forwards and backwards now to;):D[8D]Well done;)
A commer with even bigger boost will be appering on a screen near you soon!
:p Thanks every one and a very big thanks to Panky & Jon. We had a few teething problems mainly a pair of mole grips clamping the fuel return pipe :I fitted when we thought there was a fuel issue when it wouldn't start. :I
Amazing what you can do when you get the right information Thanks again Jon,
We also needed to lower the radiator about ¾” so the bonnet would shut, the exhaust was blowing a little but that’s sorted now.
Managed to by-pass the sensor in the mirror so the immobilizer is now off all the time.
I've got more videos to post but the internet has been playing up at home so will post them ASAP.:):)
Gladys & Bernie
Thanks Guys,
The internat is still playing up at home [:(!] I can't post videos from work, :(
I refit the brake survo last night and made new pipes up so I will connect it up tonight,
The new K&N Filter should be here to day :p once I have fitted it I may take him for a long drive see how he behaves :D
Gladys & Bernie
Thanks Guys,
The internat is still playing up at home I can't post videos from work,
I refit the brake survo last night and made new pips up so I will connect it up tonight,
The new K&N Filter should be here to day once I have fitted it I may take him for a long drive see how he behaves
Are the new PIPS french?? Or is this a new form of airbag?[?]
Ireland here we come.
Here are some Video's of Mr J last Weekend Hopefully :p
http://s638.photobucket.com/user/Gladyscrew/media/Engine%20Swop%203/20130427_125014_zpsded94289.mp4.html
http://s638.photobucket.com/user/Gladyscrew/media/Engine%20Swop%203/20130427_125859_zpsdf3a7f94.mp4.html
http://s638.photobucket.com/user/Gladyscrew/media/Engine%20Swop%203/20130427_131200_zps6c6691c9.mp4.html
Hope these work.:)
Gladys & Bernie
Apart from, a massive well done Bernie & Panky.....can't help but notice that Heidi played a crucial role in unblocking the fuel line:I.........still, as Panky says 'it's a mans world':D:D
it's like a man can NEVER find a lost item, be it a document or a tee shirt...one can g/tee the woman will find it in an instant! ......
Also, very strange that Mr P is wasting a whole bottle of £1.99 fizzcahol[:0][:0]
Brilliant work guys....:D:D[8D][8D]
As an afterthought ........................can't help thinking Bernie looks ever so slightly disappointed ???? or maybe just overwhelmed? :)
;)I spent yesterday afternoon tiding the wiring, fitting the carpets back in, put the air filter on, even got the screen wash bottle mounted in the engine bay.
Then Heidi & I went for a run we did about 12 miles Mr J ran really well but above 40 mph they was some vibration I am thinking from the prop shaft.
So I am going to take it off and take it to the prop shaft man and get it extended and balanced which should you solve the problem :)
Gladys & Bernie
Gladys & Bernie
Have you tried moving it round on the diff? that sometimes cures vibrations. Sometimes it makes them worse too.
Excellent work btw. It just needs a coat of primer and some torque thrust D's, like this
The existing prop was too short so I had a small extension made just as a temporary measure.
Now I am happy that the engine fits and is running ok. I need to get the prop professionally extended & balanced.:)
Gladys & Bernie
:D:D Been adding some toys
http://s638.photobucket.com/user/Gladyscrew/media/Engine%20Swop%203/DoorWindows_zps913c889f.mp4.html
http://s638.photobucket.com/user/Gladyscrew/media/Engine%20Swop%203/DoorLock_zpse83ef15c.mp4.html
Gladys & Bernie
