It was a while ago but some of you may remember I set about doing some wood work repairs on Ted the Traveller. Well to say things developed is a little bit of an understatement
He has been bodged and filled and bodged again over many years, I found seven layers of floor repairs in on place and one of the spring hangers was full of filler
So a monster panel order went in to completely re-build both sides - front door hinge panel with backing panel, front and rear inner sills, boxing panels 'B' post repair panels, rear wheel arch repairs, front spring hanger for leaf springs as well as a wallet walloping bill for replacement timbers.
Nasty inner wing and hinge panel
New hinge panel fitted
Inner wing repair and hinge panel backing panel
New bump stop made up and fitted
A bit of fettling and some boxing in later
The cowl is usually welded over the bump stop but as it's a real rust trap I held it on with tech screw for now and see how it goes.
There was also a LOT of work gone into re-building the rear chassis section in that area too.
