Only 1 way to find out..But will the wheel and tyre squeeze into the space to fit it onto the hub? Hopefully yes.yy
Might do...Nah, put it back to original.....
The fitments are identical. I'm worried that going to a bigger piston will equate to more pedal travel even with a bias valve. Sticking to 3/4 wont be a problem as the Spacevan standard ones are 3/4Can the back plates be modified to take the cheaper ones?
When I get a stuck cylinder, I screw a grease nipple into it. Using a grease gun this will force out the most reluctant of pistons. Works every time. The one that moves first can be held in using suitable spacers and a vice. Main problem then is cleaning out the greaseWell I took the blow torch to the seized rear cylinders. I managed to save 1 so I can rebuild that no problems. The other side... not so much. Unfortunately my axle is a pre 67 so it uses a 3/4" bore cylinder, which are pretty much 3 times. the price of the later ones...
Good idea! I used compressed air and heat. Worked well but one of the pistons was too corrodedWhen I get a stuck cylinder, I screw a grease nipple into it. Using a grease gun this will force out the most reluctant of pistons. Works every time. The one that moves first can be held in using suitable spacers and a vice. Main problem then is cleaning out the grease![]()
Haha. Not quite, roof...And embedded in the Man Facility wall![]()
Yes they are. They were rebranded as TAZ 1500At least they are water cooled
Wikipedia says the vehicle is still being produced by Ocelot Auto, a small manufacturer situated in Žacléř in the Czech Republic
