I'll bare that in mind Andy
And so to oily bits
Both Bonnie and Harvey had an advisory on play in the main relay lever. Obviously not enough to fail but the little bit of wander you get while driving a Commer seemed worse after he pointed it out, probably my imagination but It had to be done - and so to work.
Somewhere in this grotty mess under Bonnie is a relay lever:I
Three ball joints and four bolts are all there is to undo.
Last ball joint about to be cracked
You can just make out the last bolt amid the grime.
It's out
and in bits
Old and new pin
New bushes pressed in making sure the grease grooves are correctly positioned. It was easy to get the old ones out using the head of the old pin as a drift.
The bushes need reaming once they are in place, luckily I had the right sized expanding reamer for the job
Finished article
and bolted in place
I haven't had a test drive to see if the wandering was my imagination but there definitely was slack in the old pin and bushes.
Another good job done cheap - Harvey's next
