Windscreen removal
Hello All
Wondered if anyone could advise me on the best way to remove and re fit and seal my windscreen, van was repainted and windscreen refitted with new rubber but now leaks from somewhere but cant find the source.
Many thanks
Cemlyn
Hi cemlyn,it may not be your screen leaking who did this yourself or auto glass etc?(get them to come back if your sure it's the screen leaking)?
it could be your heater? squeezed your bulb lately? or is it still connected? are you just finding puddles in the footwell?
it could be your roof leaking? or a leak from where wipers go through body?
next time it chucks it down with rain(you shouldn't have to wait long)
get in the back of the van,see if you can see the culprit feel all the way round too,if nothing & you still have rain or wait for another day get the roof up do the same again you may find some dripping in?worth putting some cups to catch the drips.you may have to follow the drip to the entrance which could be much further away.Other sources of water getting in perrished/missing seals on the side doors & windows
The Colonel Mustard
I had this after refitting the screen with a new seal. It seemed that the water ran down the outside of the windscreen, flowed to the corners and then seeped in under glass between the seal. Then when driving in heavy rain water was forced over the top of the screen.
Bought a tube of black sikaflex (black tigerseal or any PU sealant will do) and squeezed this in, no more leaks! (though I doubt I'll ever be able to get the screen out again...)
cleans up well with white spirit, so easy to do a neat job.
come to think of it i still had wet carpets after ding this - the headlight rubbers were leaking so replaced, carpets still dry.
respray eh... congrats on getting the fix done mate; do we get any pictures?
I have only taken a screen out on a van to be scrapped so didn't care about the rubbers/ I got one of those handles that lifts with suction cups and pulled and pried and someone pushed from inside the cab with feet; none of which I can recommend as easy!
I would say that identifying the leak source and sicaflex will be the best option; if the professionals can't get it right then I doubt I would do it any better ;)
Thanks for all the tips, the screen was put in by the bodyshop last year after re spray, the water seems to collect inside at the bottom of the windscreen and then seeps down into the parcel? shelf and then the footwell, and it really does come in fast when driving in the rain, I think time to pull it out and seal it with Sikafex?
Hi Admin thought I had posted a few pics last year will put a few more up when she comes out of hibernation.
Thanks again all
condensation will run down inside the screen,especialy when you sleep in the van.You need a willing passenger & rain go for a drive.I would phone the body shop.
The Colonel Mustard
Why take it out?? Just do what sumbeam sam says and get some black silicone with a nozel on it peel the rubber back where the screen goes in the rubber and go all the way round with the sealer gun. If any prodrudes wipe it off with thinners. I took a screen out a van with its original rubber/screen and that was also sealed in from the factory so you may need to put some round. Is it a replacement rubber from martin at commer van spares?
Jon you haven't seen the mess I get in with silicon stuff [:0]
I had heard screens can still leak even with new rubbers also about the slikaflex at the factory & you only need a small chip on the edge of the screen lots of places water can get in.
The Colonel Mustard
I know what you mean it can be messy stuff you must get carried away with it! lol;)
I thought I had a leaky windscreen, ..in actual fact the wipers were going up too high snd bashing the rubber, actually forcing water to seep in, I adjusted the wiper arms so they stopped bashing the rubber and didn't have any problem after! ...:)
