We've come a long, long way together
You're probably not wrong but I did take a good few years sabbatical when my life took a wrong turn.
I've been surprised how much that I've won as the sole bidder !
A tedious but satisfying couple of hours, removing the peeling and warped fibrous older sound deadening.
Just the adhesive residue to clear now and then on goes my new Silent Coat panels, then the Dodocoat insulation.
Well onto a fifth of the rear panels so far !
Remember the Silentcoat is sound deadening so you don't need to cover every inch, you will just add a lot of weight. Give the panel you're treating a rap with your knuckles then add a mat of SC and listen to the difference. Add another a bit further along and give the panel another tap. more than likely there won't be much difference so don't waste it by plastering it everywhere.
