Tigger's Bouncing!!!!
not much sun underneath the van lol .....was good fun getting it up on ramps being a non-runner...:)
Oh so thats the excuse is itquote:
Originally posted by Enigma
Ah!! I see ....thanks John:D[8D] fairly obvious really, I was too excited to think straight:D
Hi all:) ...I managed to get my solenoid off (note the rather crude looking home-made spanner lol) a standard 25mm spanner is way too thick to fit and a special tool is available at over £10[:0] so out came the grinder for some improvisation:D Can I test the solenoid by simply adding power to it ??
lol Paul:D thanks for the compliment lol
yes I can just add power...seems to be working fine, despite its nice rusty coat!!
I took the overdrive sump off too and cleaned the filters etc...I was pleasantly suprised at how clean they they was already[8D]
I turned the gearbox upside down to remove the sump and i weas amazed at how much oil trickled out of the little hole in the top (the hole for locating the linkage alignment tool) must of been a good half a pint...I am suprised that oil doesn't spray out of said hole when the van is in use??
Result with the solenoid[8D]
There is a baffle plate under the top cover that stops the oil from up that far:I
How refreshing
ah, I see........has made me think twice about using a jet-wash on it to clean it, if the oil can get out then the water must be able to get in:I
hahaha it wouldn't stick to anything for all the crud lol ...i was thinking of very carefully putting a small bolt in the hole and taking it out after....oh, i so hope this one works this time:)
That would work, but you could use very sticky oil, crap and water resistant tape - trouble is it hasn't been invented:I
How refreshing
Originally posted by Panky
Top tip - don't don't clean this one up;)
How refreshing
Sorry Panky, I couldn't resist:I
well Tigger is up on the ramps and has had his pre-med, his operation is booked in for tommorrow morning lol...it is not going to rain, it is not going to rain, it is not going to rain!!!!!
oh and no pic but who shot Tigger?? a hole has appeared in his rear end....an almost perfect hole through 2 layers of plastic cladding!!! looks very suspiciously like an air rifle attack:(:(
Some progress:) ..old gearbox out and new clutch fitted...I'm awaiting delivery of a couple of things and i forgot school broke up at lunchtime today Doh!!! so looks work will be held up for now! so i started rubbing down the undercarriage and applying some Hammerite..OMG what a tedious job that is!!
I think I had almost as much paint on my face and arms and shoulders and everywhere really lol as I got on the van....oh, to be able to roll it on its side for a day[8D]
