sybhils still ill
Tim
I have tended to find intermittent problems to be ignition not fuel in the past.
I know everything points to fuel, but so many times I have spent an hour fannying around with fuel over and over again to find its the primary circuit - a few years ago I finally learned my lesson and now I change the ignition service items first.
HT leads (especially ebay rubbish chinese ones) breaking down when hot and coils stuttering under load.
But the main culprit for intermittant problems is the condenser. They're so cheap these days (£2) its worth sticking a new one in for peace of mind. I wish they were 5x the price and twice the quality.
As you know, with the misfiring the plugs will be fouled up by now exasperating the miss, so dont forget to wire brush them
Just another light on the subject is your fuel cap the one that is flush with the rear corner pannel or is the one with like a tube sticking out and cap on the end of it because ive had a problem with rain water filling the petrol tank up and mixing with the fuel.It did the same as your van is doin drive for a bit cut out crank over but would not fire up,leave it for a bit then start.When it cuts out try spraying some carb cleaner down the venture on the carb and see if it starts if it does then this is your answer;).The rain gutter on the rear corner at the top runs off down the corner then cacades round the fuel cap and on to the floor.The early vans had a sticking out fuel cap and the later ones had a flush fitting cap? Sticking out one is the best to have!!:D:D;);)
I've got an outie :IGlad to see someone else still awake - you on nights [|)]
lets talk about polydyne correction and mean tappet velocity......:D
or my personal favourite - flame front advance in a hemispherical combustion chamber:D
Bessies' got an outie but petrol cap is from first van and slightly loose so have had some concerns about rain in tank.
its the joys of working for the rac!! ive been on lates 12-12 so cant sleep messes with your body clock!!;):)
am typing quietly as Glyn currently sleeping off a night shift;) shame he doesn't have internet at work - could have kept you company Panky:)
thanks guys :) i have chased up blind alleys zillions of times before [}:)] so why stop now :D will try to get a look at her again tomorrow, i will try a coil change,it starts too easily to be the condenser. its an outie jon ,no sign of water in the fuel.
by the way jules, wire brushing plugs is not recommended as it impregnates the porcelain insulator with metallic particles, you get shot if you do it to aircraft [:0]
meanwhile i would like to raise the subject of polynomial functions for pressure wave reflection.............:D
perhaps better off mentioning this to your doctor:I
i did kes, he said its more a case of your turbulent kinetic energy and squish flow :D
did not get dhance to sort sybhil today :( so will give it a shot tomorrow, does,nt look like we can make the meet [V][:(!]:(
yesterday,..
got up late [V]
then got one of those nasty phone calls :(
then the riley refused to start [xx(]
Tonight rushed to tescos rushed home rushed straight into sybhil [:0]
not really in the mood for any more fun & games :(
looking forward to lots of pic's though :p
& tommorrow getting sybhil sorted [|)]
"SYBHIL" & N0.1
sounds like an interesting day[:0][V] will be rooting for you and hoping you get Sybhil back to health - best of luck:)
my feminine intuition tells me you are about to say that you have sorted Sybhil by checking coil and replacing carb - either that or your clock still on summer time and my reply shows first;)
yipeee!!!!!!!! great news:)
sorted:) after much ado,3 coil swaps 2 dizzy caps,rotor arms,points,running it on 3 cylinders with a plug sparking and watching,the only electrical fault i could find was the coil wired back to front,so losing 40% of its energy,but still no luck [xx(] so i finally went back to fueling and changed the carb for a n.o.s one we have (fixed the hole with titanium putty john) and hey presto she runs a treat now ,just been on a 20 mile run with no problems, so it was a fault in the carb somewhere ;)
wow [:0] you,re feminine intuition is amazing kes, how did you know ;):D
admin was tinkering with the BST/GMT settings before anyone even pointed it out... this time! :D
