Suspension Question
It's not, just low profile tyres, Toyota shocks and rose jointed anti roll bar ;)
Whats the advantage of the rear 5 link set up? Is it just for improved handling when taking corners at speed?
It's fully adjustable in every way, so you can set it up precisely. It gives far superior handling, locates the axle in 2 planes, stops it walking all over the place. Used with multi adjustable coilover shocks which can be set for ride height, compression and rebound damping in minutes, along with quick and easy spring changes.
Interesting. What I'm going to do is re-set the rear suspension on my van (if its incorrect - still yet to check) then i'm going to source some replacement OE springs and carry out the hi lux shock upgrade and then see how the old dear handles if its still utter rubbish I might just give you a ring. Cheers for that.
Got a set of springs here you can have :)
Would it be possible to have the bottom wishbone modified to have the spring sticking through it, having a kind of box underneath it (the front wishbone sliding "over" it) so you can keep the original spring?
Or have the front suspension crossmember rewelded to take the original suspension only puting it up a bit higher on the subframe?
I think both spring locations would need to be extended upwards so the van 'dropped' over them to achieve the effect and still use the original springs without upsetting the geometry. You could run into trouble with the bump stops and anti-roll bar though:I
Harvey & Bonnie
What can be done at the front is lower spring platforms, a stepped or lower spring cup to allow the spring to sit lower in the wishbone. Although this would still mean a loss of suspension travel, some could be re-gained with shorter bump stops ;)
But if you lowered the top spring platform, which is fixed, wouldn't that have the effect of raising the ride height?
Harvey & Bonnie
Lower the BOTTOM ones, not the top :I Drop the spring through the bottom wishbone ;)
But wouldn't that just unload the spring, surely it's the fixed top mount that will dictate the ride height:I
Harvey & Bonnie
No, it allows the wishbone to come up higher (lowering the van). The spring is still loaded the same.
I like these discussions:) But I'm still not convinced, I'm off to do some thinking;)
Harvey & Bonnie
Like this MG.
See the spacers between the wishbone and spring cup ;)
Yes I was thinking that was the way you were explaining it, it would drop a little but I can't understand how moving the lower mount down wouldn't unload the spring - in effect you are allowing the spring more room to relax so the car would naturally sink to where the unloaded spring will allow.
Harvey & Bonnie
Well it would affect installed preload, but that does not alter ride height or spring rate :)
I think I'm getting there. It's nice to learn something new:)
Harvey & Bonnie
It will lower the van without changing the springs characteristics....................It'll still bounce and wallow all over the road :D
So the geometry would stay the same as the kingpin holds everything in place and as long as you don't go mad with the spring cup lowering spacers it's safe:) It's the way to go - have you done it yet Tim:p
So to answer your question David yes you can drop the spring through the bottom wishbone and quite easily by the look of it:)
Harvey & Bonnie
