eldiablo
Member
hi all
I want to lower the subrame because I need to work on the bottom of my engine and I will leave the engine in the Fan
do I need to remove the upper control arms ,to lower the subframe ?
I was thinking of removing the drums completely with the backingplates and all so I can leave the handbrake cables in place also I want to take as less of as I can ,because its only a matter of making some extra clearance in the upper bridge of the subrame for my oilsump ...it has been rubbing the subframe and started leaking > I have to weld it and that's why I want to remove just the subframe as simple as I can
I have a P .Olyslager motor manual for the comer 1500/2500 range but that says that I need to take the scocks and springs out before I can remove the upper and lower control arms ...and my guess is that there must be an easier way of doing this
I took all the steering linkages off and disconnected the brake lines ,the anti roll bar is also disconnected so ,i'm half way there I guess
first I thought I was able to remove the upper control arms by taking off the stubaxle carrier ,but the bolts are so damn stuck !!
so can any of you guys help me out with some advice ?
thanks in advance
Philip
thanks in advance
Philip
