Straying Off The Subject Of Commers For a Second
admin 2.0
Hey Tim, have you ever seen this done before:p:p
http://cgi.ebay.co.uk/Mini-cylinder-head-kit-K100-8-valve_W0QQitemZ190249419377QQihZ009QQcategoryZ72205QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
looked into this one a couple of years back, its not a bad conversion,not as good as a KAD jobbie but yeilds 130-140 bhp. i think there is 2 types of k100 head to choose from as well, its quite involved though, lots of re-machining and blocking/moving holes and adapting pulleys for cam drive etc. not something to take on unless you have machining facilitys really.
i do remember that someone has put the whole lot stage by stage on the net somewhere. and it has cropped up on the 16v mini forum.
i think its for 1000,s only [?]
feeling brave then panky :D
Not that brave, just dreaming of a car that will go when I EVENTUALLY GET IT TO STOP [:(!]
i saw that done about 10 years ago, it worked well, but the guy had gone a bit mad with it, and machined the end of the block flat so he could drill it and mount idler gears in order to run gear driven cams !
IIRC the bore centres arent quite right, but it depends what block you start with, and how much you care.. its only like 2mm across the 4 or something.
http://www.miniman.com.au/bmw.htm
http://www.16vminiclub.com/forums/viewtopic.php?t=5256&highlight=k100
http://www.youtube.com/watch?v=974kBWoZfhs&feature=related
http://www.youtube.com/watch?v=ymPuRbmlPJU&feature=related
cant find the item i wanted but did find these :p
440 c.i big block [:0]:p[^]:D with blower and n.o.s [}:)][8D]
easier to fit a redtop or vtec really :p
Yeh but at least the heart of the old A series remains. Am I just an old sentimental fool :I
no its not :D
http://www.youtube.com/watch?v=Wa9jpDQns1M
i do know what you mean panky,but it does have its limitations,and you end up blowing diffs/boxes at a rapid rate [xx(]
