solar Panel for Gladys
Not sure about the flood light, might be too powerful for the delicate circuitry in the panel. It would need a diffuser on it to be safe even then I would power it with a petrol generator so the output could be controlled easily.
Commerfest 2015 is happening. Contact me for details :)
There is also a hydro-electric generator system for caravans and campers. This one is ideal for winter use as it utilises a block of ice on the roof (you can freeze you own in the winter). As the ice melts it drives a series of mini turbines which generate enough power for lighting and even an electric blanket. Any excess power is stored in batteries and used to pump water back up to the roof to re-freeze during the night, very efficient but the roof needs a little re-enforcing. The good news is that it works great in the rain too:D
Power from beer - it's the future[8D]
The beer will have been naturally recycled before turning it into hydraulic pressure:)
May I suggest I volunteer as the pressure vessel for the recycled beer:)
Mr Pankhurst,
I'm pleased to inform that you've been successful in your application for the post of 'Pressure Vessel' for Eco-Commer Ltd.
As discussed your On Target Earnings of 1 Keg per day is the generation of 10KW per pint of real ale.
Jim CEO
EcoCommer - 'Ur-in Control'
The Blue Toaster
Real ale, I'd throw up before I finished the first pint[xx(] Sorry I'm a heathen when it comes to beer - stick a case of amber chemicals in front of me and I give you mega watts:D
I'm real ale every day long....when I wad 19 I went out with my father in law, he refused to buy the Amber chemicals as you put it. So as I was skint I had to settle for a pint on bitter....which I still enjoy to this day.:D
If I see one more grease nipple........
Tried it and it doesn't like me:I
Mr Pankhurst,
After the recent discussions and revelations we have decided to honour the contract based on the extra Wattage you have promised to provide through lager consumption.
Jim CEO
EcoCommer - 'Ur-in control'
The Blue Toaster
It's official- I AM BEER:p
