Soapbox racer
PaulJL
Thoughts have turned to next year..... Planning on using the same body but with a modified chassis...
PaulJL
Tonight I built it up and checked for damage. The body mounts were twisted but sorted that with a hammer and adjustable spanner. Unfortunately the roll bent the upright on the back end that everything is welded to... Body gonna have to come off so I can bend it all back straight
PaulJL
All 4 wheels off the ground... I count that as serious air!
That ramp was mental!
PaulJL
Body off and chassis stripped. The toll twisted the frame at the old pedal crank bearing housing. Warmed it up and tickled it with a hammer. It's OK now.
Found loads of straw in it for some reason. No idea where it came from....
PaulJL
New lean mechanism is underway, sacked off the trampoline springs. New method is rubber blocks :) hoping to mount a bracket inside to fasten a smoke discharger into
PaulJL
Modified lean mechanism, small compression springs inside sleeves of old bump stops. Will give a progressive lean and a positive stop... Hopefully
PaulJL
Bit more tinkering today. Built a mount and modified a spray can trigger to make an air freshener powered rocket booster :) smells nice too
PaulJL
No pics as yet but I modified one of the foot pegs into a pedal to activate the smoke, mounted a siren and added more weight
