Shabby snout
Nice one Trev[^]
My flap has completly disintergrated so I'll need to remake it - a job for the summer:)
Harvey the RV
There's nothing much worse than a disintergrating flap[:0].I had to make a new one as well. A strong piece of boiler casing did the job[^]
back to my "rootes"
Hi Daytona, all information in this area gratefully apreciated - good and bad.
Panky, how about making a new flap out of perspex?
"With great cars comes great responsibility"
I had a good look at Brian's heater box today layed on the floor in the cab, it looks pretty crusty and has been painted with black hammerite, however the heater works brilliantly when the bottom flaps under the dash are open, really toasty.
The vents that blow up to the windowscreen don't seem to work as well though, even when I close the bottom vents, the pipes feel ok, where else should I be looking or is the blower poor on the screen vents?
Moley and Brian the Snail :)
Originally posted by daytona
Sorry to have been a bearer of such bad tidings regards the air box, but it was a job that wasn't overly important in the scheme of things so it took rather longer than it should have done. It is now finished and fitted back in, seems to work OK too. some pic's
[imghttp://i216.photobucket.com/albums/cc27/daytona_com/airbox001.jpg?t=1255290152
back to my "rootes"
Cor I wish mine looked like yours, brilliant:D
Originally posted by BigMonkeyMan
Hi Panky, how about making a new flap out of perspex?
And watch the moonlight flood into the footwells :)
Harvey the RV
Oh dear, i have this job to do too:-( good thing is though is that i have got and old washing machine in the garage which will be useful for the donor metal;-)
My name is Scott, not Comm-Don!
bin busy cobbling my heater box back together today.
its not pretty, but no one is going to be seeing it anyway!
"With great beards comes great responsibility"
Oh so familiar:I Watching this with great interest as it's one of the job I've got to finish - and I've forgotten how it goes back together:I
Hi Panky. Do you want me to take any measurements before I stick it all back together?
I ground down the welds and set up to paint it with Hydrate 80 today, but it was frozen [:0]
Very nice work indeed, I just wish our airbox have enough metal left to actually work with [:0]
Good to see another fan of Bilt Hamber products, I've always found them very nice to use and reliable results. I'm not related or on commission but others may want to check out their products at http://www.bilthamber.com/index.html
Commer 'Hi Tor' by TorCars
I still think a fibreglass air box is the way to go. Now I know mine comes out with screws, I think I am going to attempt to fabricate a mould and then a box
Another vote here for Bilt Hamber products, don't be put off by the name either - they're a British company.
Peggy's got an MOT !!! (not a lie)
As I am about to remove my heater box today does anybody think that getting it shotblasted (after it is repaired and made solid) and then getting it powder coated might be agood idea before it goes back in[?]
Hi,
Is the thingy in question not a heater, but a secondary engine cooling thingy to keep the van cool going up hills +5degrees. There are two modes hot, or very hot. When using this technique working quaterlights need to be functioning to avoid dehydration. The handbook also recommends drinking water a plenty, else know what that little lever on the engine is for!
Top tip, a hosepipe conviently fits on the input and output of the heater, i.e. a flush is possible in situ.
Top job on the welding!
Very good plan. As with most things commer related, once the rust is in the seam its a bit of a pain. It is constantly wet and warm so ideal for rusting - I put a load of wayoyle in mine too, but painting the inside was a little tricky.
show us the piccies!
Originally posted by andydna
Hi,
Thanks for the hosepipe tip - I'm planning a cooling system refurb this winter and I was wondering how to get it properly flushed.
I'm not scared of hills - last week we took on the Berredale Braes with Jessica and she performed impeccibly - had to knock her out of overdrive for a moment though ;)
Removed the heater box and everything else and was left with a decent front panel:
Heater Box has got rot on one corner and the lower pipe has rot as well. The flap is in a good condition considering. I will have to get a picture of it before I strip it down.
