Hi I've been looking through my maintenance chart and I noticed there's a filler cap on the back axle, how often should I check the level in it? Finally do some of the lubrication points just need a squirt of oil on them?
Good idea to check the axle and top up with EP90 if you can find some. Cant really think of many oil can jobs besides door hinges and carb linkage maybe.
Had a look but there's to many to choose from, has anyone got any suggestions. I will be having a look at it tomorrow, the level should come up to the bottom of the filler cap?
Yes, make sure you clean around the filler plug so no crap can drop in when you take it out and top up until you can see it brimming. You can use the same oil in your steering box at the base of the steering column.
