Been a while since I've done anything with Peggy due to weather and work. But I have this week off and the weather was good today. So I decided to have a look at the indicators.
The problems seemed to occur when the hazard light switch was used- no hazards and then no more indicators. I popped the connector off the back of the hazard switch and it all looked OK. I put it back on the switch and tried the indicators. They worked! I then tried the hazard switch - no hazards and the indicators stopped working again. I removed the connector again then replaced it - indicators working again!!!!!! Did this a couple of times and the result was the same each time. Any ideas?
I also noticed that when the indicators were switched on the hazard tell-tale light flashed once then stayed off.
Weird eh?
I also fitted the steering column shroud but it kept shorting out the horn! Some judicious use of insulating tape seems to have cured that. Anyone know the spec of the little screws that hold the two halves of the shroud together? I'm missing one.
Found more damp in the side panel behind the passenger seat, similar to the driver's side. I'll have to try to seal the roof seams before next winter.
Fitted a known good leisure battery in place of the one she came with (this is now trickle charging to see what it's like). Checked the charging system for the leisure battery and all is good. The water pump for the water tank works (electric) but with little/no water in the tank I don't yet know how well.
Going to look for a new washer reservoir/pump unit as the one fitted sucks - that is, it doesn't!
Have also looked at some of the wiring under the dash - ooer! Lots to do when the weather really improves. Also need a Hi-Fi (I removed the bolt on ariel base that was fixed to the n/s mirrors - may go with a windscreen type ariel instead.
Off to eBay! Back soon.
Peggy's got an MOT !!! (not a lie)
