PEGGY
They're only guidelines though, the law says 70.
Peggy's been to Snetterton!
Originally posted by bazzateer
Originally posted by renaultvation
76 mph [:0] Isn't that exceeding the national speed limit! ;)
Shouldn't you be setting a good example for the rest of us to follow! :D
ACPO guidleines for prosecution are speed limit (70) + 10% (77) + 2 = 79mph. ;)
I love a bit of inside info me;-)
HAHAHAHAHAHAHAAHAHA!!!
No secrets, it's all here:
http://www.speedlimit.org.uk/faq.html#ACPO
lord lucan Posted - 08 Jun 2010 : 23:00:26
I have had to keep quite for a while but now I have read the boys in blue bend the rules a bit I can start chatting again
So can I! ;)
Took Peggy for a run out to Andy's workshop to help him with Babs yesterday. She started and ran with no problems. I did notice that she was nearly out of fuel though but thought she'd make it back home OK. The needle very quickly went to E as I made my way home. So no max speed runs this time, it was all about economy. And she did it! The cheap petrol station is downhill from home so I'll fill her up tomorrow ready for Friday.
This morning I decided to check if the fridge was working. I hooked up the 240v supply and it worked fine. The 12v supply needed a cigarette lighter socket nearby, which I didn't have so I've extended the cable. Didn't get a chance to check it though as I didn't want to run the leisure battery down too much, The run up to Commerland should show if it works.
I also lubricated the sliding cupboards as they were sticking a fair bit and fitted a new switch for the outside light which now works!
So, looking good for Friday.
One thing is bothering me though. Peggy's gearchange is playing up. It's hard to get the lever into the 1st and 2nd plane. This started to happen once I started using her a bit and has got slightly worse.
Is this likely to be a case of adjustment? If so, is it something that can be done say, in the middle of a field in Yorkshire?
Peggy drinks too much!
It's probably play in the linkage, someone is supposed to be makeing me some new bushes, to take out the slack, but they havn't arrived yet [?]
OH.....err....ahh.....umm....... they should be there for commerfest :I
Originally posted by Stan n van
76mph, maybe we should organise a drag race at Commerfest a la top gear:p:p Still trying to work out what is thirsty by Commer standards:I I have established that once the fuel gauge is just under 1/4 it is empty;) (well under 1L it appears. I am investing in a bigish petrol can for those motorway runs:p
Bring it on[}:)][}:)]
There is more than one linkage in the contortionist route from lever to box. If its the final slip linkage into the back of the box then its easy to adjust in a field, and does make quite a bit of difference.
I might be borrowing your expertise in that case Jules!
On Monday morning Martin put Peggy up on the ramp and adjusted the linkage to give her four selectable gears again. One slight hiccup meant she no longer had a functioning overdrive but another fettling session got that sorted - Thanks Martin!
Other than that Peggy performed faultlessly over the weekend returning an overall 25 mpg. The only issue, and a relatively minor one, is that with the heater tap seized in the on position it did get quite warm even with the windows open. So today I fitted a new 'tap' into the heater hose so I can now switch off the heat!
I also found some spare gauges including Oil press, oil temp and vacuum. I connected the vac gauge to the manifold and it works nicely - so when I get around to it I'll be fitting it to the dash along with the oil pressure gauge and a tacho.
I'm interested in the vacuum gauge fitting. Was it just small bore tube, the same as vacuum advance? Did you drill a new hole in the manifold or use a t piece on the vacuum advance tube?
Hi Rupert, sorry for the delay!
Peggy's inlet manifold has a small vac take-off near the dip stick end which the tube just pushes onto. Windscreen washer type tube will do as that is what is on the gauge at the moment.
Peggy and I have just got back from a 5 day/4 night trip to the 11th annual Wicked Welsh Weekend with The Imp Club. She performed faultlessly and returned an overall 24mpg which I'm happy with as we were doing 60-65mph on the motorway and going for max speed whenever possible!
Managed to get her up to a max of 77.6mph! 1.6mph more than my previous best![8D]
Pics are uploading so I'll post them later.
Need to calm your jets Baz.....I thought you were only allowed to travel at those speeds when the blue lights are on:I:D:D[}:)]
HAHAHAHAHAHAHAHA!!!
And I was overly imp-ressed by the Bluebird hitting 60mph (for less than half a minute) in strong tail wind when I crossed Denmark..
I obviously live in my own little bubble :I
