Overdrive Dashboard flick Switch
Hello all I’m after a Dashboard Switch for overdrive 3 terminal, So the ones I see on line are expensive, I think I may have found one but not sure of amp rating 25 amp ? It’s so long since I’ve put one on Thanks all
You could use a triumph 2.5 gear knob which has a switch on it, together with a relay which you can put anywhere . It's much more intuitive and easier to operate having the switch on the gear knob.
Parts are going a bit crazy since Matin and Speedies stopped. Show just how important they were to us all.
If you brave FB there’s some vans being broken - maybe one has a OD in it. I’ve had some bits from Luke H, he’s recently split two.
