Hello all I’m after a Dashboard Switch for overdrive 3 terminal, So the ones I see on line are expensive, I think I may have found one but not sure of amp rating 25 amp ? It’s so long since I’ve put one on Thanks all
You could use a triumph 2.5 gear knob which has a switch on it, together with a relay which you can put anywhere . It's much more intuitive and easier to operate having the switch on the gear knob.
