Thanks panky from the help I get on here it gives me the confidence to have a go ,, I think if u own an old vehicle u need to have a go or u will have empty pockets , I actually enjoyed it , do u think brake cleaner would be enough to clean up everything ? Drums look in excellent condition no burrs ,shoes look good to, when removing the cylinders and brake pipes do I need to remove master cylinder cap or do I just back off on the drum brake adjuster? Also do I have to bleed whole system after new cylinders on that drummThanks again for the help really appreceatedYep that cylinder is toast, I'd replace both to be sure. If the bores are OK you could fit new seals and keep them in the spares box. Good to see you're supporting the van safely too.
A spray of water is fine for keeping the dust down but get some proper brake and clutch cleaner to finish off. It looks a lot simpler than the single cylinder set up so you shouldn't have to much trouble, take care disconnecting the brake pipes though as they a easily destroyed. I'd start spraying the connection with penetrating oil now, and do it daily, to give you a chance of saving the pipes while you wait for the spares to arrive.
Thanks soupdragon I was thinking the same myself about holes connections ect line up , I may have found a set , but want to check out if I it's cheaper to get them relined here , impressed that u actually changed urs , hopefully when I do mine they will last 25 yrs , i am just going to check the back ones while I,m at it and get spares for them to .I’ve not done shoes for decades. I imagine that you need to check that all the connections are the same too. Bolt holes etc and are the drum diameters the same. 2 pot are more powerful than 1 pot, I think. I’m being a bit vague sorry but it’s been 25 years since I changed a shoe.
hi soupdragon , as far as I know we dont have a border anymore , Ireland is terrible for classic van car parts unless it's that eircooled unnamed vechicle , loads of parts for them , I was thinking of setting up a shop myself here but I dont know if it's worth it , only 6million people here and very few classics , as for the relining they reckon it takes about an hour , they still arent 100% sure they can do them until they PHYSICALLY see them , I dont get it , I thought the relining process would be the same for all shoes anyway the cylinder arrived today still havnt opened the box to check them , fingers crossed , I should of got rear cylinders aswell , bit concerned doing the brakes ,due to the material in the shoes , I wish I was 20 again were u dont know care about the dangers out there , anyhow I will be like an astronaut when working on them , thanks again for helpGetting them relined would certainly be easier for you. With a bit of luck they may be able to tell you what other makes are the same. It would be useful to have a pair spare so you could still drive it while waiting for them to reline the worn ones. Pity there isn’t a shop just over the border you could then smuggle them back lol.
hi panky could u tell me do i have to have cap of master and do i need to turn that cog to loosen before taking off van shoes ?I can't see any sign of rivets on the back face of the shoes so more than likely bonded, Good news you found a place to re-line them.
Thanks panky , I am not sure if the brake shoes are the originals or not as the van only has 69.000 on the clock , as far as i,ve been told it went from the original owners garage to another garage ect , hasnt really being on the road , i,ll take precautions anyhow . Should I just spray it down with plenty of brake cleaner Cheers mateNo need to cap off the master, you'll loose fluid anyway when you change the cylinders and you will need to bleed the brakes. Back of the adjusters to make things slightly easier to get the shoes off and on.
Don't worry about dust just make sure you dampen everything down, modern brake linings don't contain asbestos.
