Originally posted by nancye
Hi,
been having similar type problems myself...
back in july tramps started chugging occassionally, then back firing seriously...
so I put in new points, condenser, rotor arm, dissy cap, coil and ht leads.... few hundred miles later we conked out again... moved the coil to the wheel arch.... then changed the condenser and points again.... thought the problem was sorted, been moving around locally without problems, and then today just as i was embarking on a longer journey from brighton for worcestershire, I lost all power... luckily i was within 3miles of my mechanic, but by the time he had a minute to take a look, tramps was happily purring away again.....
whhaaaaaaa....!!!! tempermental electrics are more frusrating than a broken engine.. [
i'm now thinking it could be dodgy old wiring somewhere between battery and coil but any other suggestions grately received....
hows smurf doing???
Smurf is 'ok'......with a poss 26 vans going to Coventry, I'm hoping some kind soul will have her running a little smoother
