My Humber Super Merc
Im sure this is the modual on the wiring diagram
A commer with even bigger boost will be appering on a screen near you soon!
Originally posted by Gladys Crew
Jon are the wires are Green & White which come from the ECU to the module, I have jointed these together with no joy. Is it possible that it needs either a resistor or diode just thought of this one so not tried this.
Gladys & Bernie
It was def two different colours you have to join.
Have you got a wiring diagram for it bernie??
I have got a DVD disc full of wiring diagrams but not the right one the hayne manual does not match excatly so making my own as I go along, :(
Gladys & Bernie
do you want one:D;)
Ive got one just for the alarm system if its any use??
Hi Jon
That would be great if I could have a copy I woul be very greatfull :)
Gladys & Bernie
Pm me your email address bernie and i will see if i can get it on to an email;)
I've sent you an email let me know ;-)
Diagram sent hope it does the trick as i think this is the area of the loom where you problem is. You will need to fit the warning lights out the mirror to the loom for the humber so you can see whats going on if you havent got a constant green light on led it wont run the fuel pump or fire up;)
No probs let me know if I can help anymore as I love a good engine transplant;)
Got Voltage to Fuel Pump, Got a Spark :D:D
http://s638.photobucket.com/user/Gladyscrew/media/Engine%20Swop%202/DSCN1373_zps6747aa73.mp4.html
Filled the radiator with water put 10 ltrs of petrol into tank, then tried to pime the pump lost the voltage to again [:(!]:(
But I know that with Jons help we have solved the problem. It was the immobilizer it must of thought I was trying to steel the old Merc
Got Mr P coming round in the morning and the Humber Super Merc will be running :D:p
Gladys & Bernie
Sounds like your heading in the right direction Bernie;)
Ok Guys & Gals please watch the video advice needed :)
http://s638.photobucket.com/user/Gladyscrew/media/Engine%20Swop%202/20130407_142315_zps4c289c1c.mp4.html
This has Panky and myself as a loss. The engine starts but as soon as it fires it stops again, the pump runs and there is always a spark
Gladys & Bernie
It was a frustrating but educational day:I I think we learnt a lot about the engine and, after a few red herrings, found and fixed a few issues. But even after our best efforts with combine brain power of at least 500GW the flippin thing just won't run:I
The trouble is it's got lekkytronic stuff on it;)
I think it's a crank or camshaft sensor, no idea what I'm talking about, but sounds good :I
