Think I might need a bit than luck this time as I haven,t had time to find out whats clunking when I go over bumpy roads or over fields at shows, think it's on the suspension as I can't feel it through the steering
back to my "rootes"
Check where the anti roll bar bolts onto the lower wishbone. The two bolts can work loose and clunk every time you go over a bump. Mine do this every few months no matter how tight i do them up!
Well cant believe that it 12 months since I started this thead but Gladys is going in for her MOT again in the morning[:0]
Just been out greasing her nipples, freeing off the hand brake cable which was ceasing up but managed to get some grease in it and its working fine. I also adjusted the brakes up tested the lights wipers horn etc. so finger crossed all will be well.
