MOT Time Again
Enigma
Congrats Trev[8D]
Originally posted by daytona
Think I might need a bit than luck this time as I haven,t had time to find out whats clunking when I go over bumpy roads or over fields at shows, think it's on the suspension as I can't feel it through the steering :(
back to my "rootes"
Check where the anti roll bar bolts onto the lower wishbone. The two bolts can work loose and clunk every time you go over a bump. Mine do this every few months no matter how tight i do them up!
I just need a good rootes...
Nice one Trev[^]
Could also be a worn anti-roll bar drop link joint
Summer's Coming
bazzateer
Well done!
Bernie, what happened to the Humber SuperMerc thread? I cannae find it cap'n!
renaultvation
Here it is, in 'Other Projects': http://forum.commervanfan.co.uk/topic.asp?TOPIC_ID=7710&whichpage=14
bazzateer
Ta!
Gladys Crew
Well cant believe that it 12 months since I started this thead but Gladys is going in for her MOT again in the morning[:0]
Just been out greasing her nipples, freeing off the hand brake cable which was ceasing up but managed to get some grease in it and its working fine. I also adjusted the brakes up tested the lights wipers horn etc. so finger crossed all will be well.
Gladys, Heidi & Bernie
Gladys Crew
Originally posted by Panky
It'll be right:)
Yet again John you are right, Gladys PASSED no advisories :D
